Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
List not correct
4 REPLIES 4
jdk5225g
221 Views, 4 Replies
List not correct
I have a simple structure going but when I number the columns or shear plates there always seems to a few that are different. I did "differences between objects" and found no problem. I did group the shear plates and a query for the columns, the look good. I checked the "number by holes" , I assume that should be checked. Need help
Joseph
4 REPLIES 4
Lewk_PSB
in reply to: jdk5225g
Try running the "AUDIT" command, which helps get rid of duplicate holes. Check all parameters (coatings, material, etc.) to ensure they're all the same. "OVERKILL" can get rid of duplicate objects. Outside of the maintenance I just mentioned, the parts must be different in some way.
sdonohoedesign
The command 'LIST' is sometimes helpful in this situation.
Make sure you number the whole model
jdk5225g
in reply to: Lewk_PSB
will check it out, thanks
jdk5225g
yep.....works for me
