I have beams coming into my model with a line type scale of 20.00, plates are coming in with a linetype scale of 1.00, Bolts are at 20. This is causing grief for some of our non-structural departments who use a standard autocad viewport in paperspace to look at the model and their sheets do not print right. The hidden lines in the beams are showing up solid. Is there a setting somewhere that will make all the items in the model be inserted with the same linetype scale? I can't have them being different and manually changing every beam may be a solution but it is not a good solution. Also, we are a design firm, not everyone here uses advance steel so having all sheets in the project be advance steel views is not an option. I just need everything in my model to have a linetype scale of 1.00
Thanks.
