Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
labeling
2 REPLIES 2
desigan2015
228 Views, 2 Replies
labeling
Dear All,
I used the drawings style - 3d view -object selected - w/0 Lables
once the drawing generated , i tried to give labeling , but instead of section name Main part mark only comes. I dont need main part mark , i only need section name. Please refer the attached snaps accordingly . Please advisestep 1step 1step 2step 2step 3step 3without editing , i would like to have section namewithout editing , i would like to have section name
2 REPLIES 2
sampie
in reply to: desigan2015
This functionality is controlled by "Tokens". In the list of Tokens, choose the option "Part Name" and it will automatically pick up on the section name.
Kind Regards,
Sampie
_______________________________________________________________________________________
If you find my post useful, please give me Kudos. If my post solved your problem, please accept it as a solution.
youtube.com/prokonbuild
rbolinelfers
in reply to: sampie
You can also change the token semi-permanently when doing manual labels....
1. Start "insert label" command>enter the letter "C" to edit content definitions>for the beam, plate, etc.-expand the entity and replace the token the is defaulted.
2. You can reset this back to the defaulted token if needed.
