LABEL TEXT SIZE IN DECIMALS
I WOULD LIKE TO TO SET MY ALL THE LABELS IN DECIMALS OF INCH INSTEAD OF FRACTIONS HOW CAN I CHANGE IT?
AleckGiles
Try going to Project Settings in the drawing you are interested in. Then choose ht epage for the required parameter e.g. Length Units and set the unit format to Decimal. Do this for each type of unit you are interested in.  Then edit the Dimension Style AS_DIM_Style1 setting the primary unit to match.
This only affects the drawing you are in so it is best done in the prototypes so that all future new drawings get htese settings.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
