Key Plan View Drawing Style in AST 2020 UK Version
After watching a YouTube video recently I've been trying to find the Drawing Style "Plan View - Key Plan" in the "GA - Plans" tab but it only seems to be in the US or Australian version, can this be moved from one version to another or imported somehow?
YouTube "Advance Steel 2017 - How to reference connections created by camera to a key plan view"
CHRIS_ASDL
This particular drawing style isn't available in the UK version. If you start AS in the US version then you can export out from one country version to another, using the import export tools in the document manager.
Instead of importing the drawing style, you can quite simply add the camera to the object presentation of the drawing style you are looking to use. I've added this option to both plan views and 3D views.
You will most probably want to change the camera label, as the out of the box one comes with the awful camera hatch. @Sebastian_Eiche has done a really good video on this
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/simplecontent/content/camera...
Kind Regards
Chris
