ifc file - cat ladder and railing elbow not shown in IFC
desigan2015
desigan2015
Dear All,
i have converted my model into IFC files ,
but i cannot see the catladder cage , rungs and band in ifc file .
railing elbow also not shown . anybody can advise .
desigan2015
bolts also missing
desigan2015
Dear  all , when i am using the option 1 and 2 getting some problems .
option  1- the file size is 112 MB , clients said they cannot upload the because of the file size.(all the members can see )
option 2  -the file size is  30 MB only but bolt nut , cat ladder cage  and railing cannot see .
is there any option to convert IFC file with minimum 40 MB file size .
please refer the snap.
ArjunGaba
@desigan2015  Please select all the members and click on the object properties select it to standard . After this slect all bolts, studs ,anchors and choose display type to solids Than select the members to create ifc file .
desigan2015
what is the difference between these 2 options
gilbertBP5AH
Observer
Observer
The information for "Assembly Mark" (ID) will show if you use option 2. Cheers!
sales7NF7D
Is that at new feature.  I don't recall the Assembly Mark (ID) showing up in the past.  Which version of AdS are you running to get that to work?
