Some of automatic detailed parts (object) are not oriented as I want.
I know, this is dependent from UCS orientation when object is created.
For assembly orientation we use "Define assembly detailing orientation" to change orientation of assembly as we want.
What about "Define object detailing orientation". How it works.?
Please more about detailing orientation is very appreciated.!
It works the same as the "Define Assembly..." button, but only changes the orientation of SINGLE PARTS. Set the UCS to view Y as "up," and z pointed at the viewer as it relates the the particular single part you want to change the orientation of.
Thanks..! Finally I have understood it.
Let me go more deeper. I have changed the orientation of part but now I want to undo it in default orientation.
I guess that I can use the same command to default orientation (believe me is very hard to find default orientation, lot of attempts).
Does it exist a fast command to define default orientation of part..?
Anyway thank you..!
