How to Create a MDB File.
RubenBergs
Message 1 of 8
RubenBergs
Hi All,
I need to create a MDB file as this will need to be used with another program.
So my question is what are the steps to do this, as I really need to know how to do this.
If someone can help me with this I would be very grateful.
Replies (7)
Message 2 of 8
Sebastian_Eiche
MDB files of what?
You create a model in the modelarea of a dwg file, what should be write in the mdb file?Singlepart-, Mainpart- or Detaildrawinginformation?
There's no button for exporting mdb because this is a database file, maybe they could be a way by exportng a bom list to excel and then import this into a mdf file...but without information about what you gonna want to do, we could not help you
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 8
RubenBergs
@Sebastian_Eiche
Thank you for your reply,
I need the MDB file so It can be used in a program called Optimus, the MDB file has information related to the model which Optimus uses.
I have been reading that previous version's of Advance Steel used the MDB file but now it's change to a MDF file.
I need to have a solution for this.
Message 4 of 8
bigcarl5000kg
Hi @RubenBergs,
have a look here for the solution as needed:
https://learn.microsoft.com/en-us/sql/integration-services/import-export-data/import-and-export-data...
https://youtu.be/Ir2YUXQJjUI?si=dejcdbLgrzzIhFT3
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 5 of 8
Sebastian_Eiche
You will not get a MDB of the actual version of Advance Steel, this could only be done by converting MDF as @bigcarl5000kg wrote.
Mdb are not used since 2018...
But I could not imagine what information could be used from this file. As I know there're some information about extracts from the model but it's been a while since I looked at it.
The software Optimus is present in environment, what is it used for? Maybe we found another way.
Sebastian Eiche
Message 6 of 8
bigcarl5000kg
https://towardsdatascience.com/data-science-with-optimus-part-1-intro-1f3e2392b02a
Message 7 of 8
bigcarl5000kg
you simply irrevocably borrow data from another system and then implement it highly intelligently 😁
Message 8 of 8
RubenBergs
@bigcarl5000kg
Thank you for sending this Information I will go though and see if I can make sense of it.
