special part, made from a acis solid to form the dome shape, stored as an plain Autocad file, then inserted into the model and attached to the end of tube with a weld.
if it is a standard size you may find some predefined solids out there on the web
John Bennett
Hello, either make a file with the special parts (have the weight, material, etc.).
Either save each model in the Symbols folder
Hi @johnjmbennett ,
It is unclear to me, do you have some tutorial that shows what you meant?
thank you
Help | Special Parts | Autodesk
Special Parts - Autodesk Community - Advance Steel
ADVANCE STEEL: Quick Tips - "SPECIAL PARTS ON DRAWINGS"
