How to change the display of Solid round objects on drawings
- Mute
- Permalink
- Report
You can change the display from the Advance Steel Management Tools Default category.
Default>
Check Use filter
Type “Solid objects”
Select System>General
From the Property Value for the Solid objects-body approximation
Change the default 0' 0 3/16 to 0’10"
It’s not perfect, however the display will be much better.
Remember to Load Settings in Advance and back in the mode structure Update defaults.
Update the drawing. If that does not work, recreate the drawing.
Please see attached PDF for a Step by step.
I hope this helps
Janet
Graitec CANADA
