How to change the display of Solid round objects on drawings
janet_black
janet_black
You can change the display from the Advance Steel Management Tools Default category.
Default>
Check Use filter
Type “Solid objects”
Select System>General
From the Property Value for the Solid objects-body approximation
Change the default 0' 0 3/16 to 0’10"
It’s not perfect, however the display will be much better.
Remember to Load Settings in Advance and back in the mode structure Update defaults.
Update the drawing. If that does not work, recreate the drawing.
Please see attached PDF for a Step by step.
I hope this helps
Janet
Graitec CANADA
Dias_Antonio
Dear Colleague
Thanks for help
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
lim.wendy
@janet_black ,
Thanks for sharing!
Delighted to have you as part of the Autodesk community!
Wendy Lim
Data Nerd | Community Advocate | AEC Industry
facebook twitter twitter blogs pm
Join the new online Rail Community
Rails Summit
Thanks for help😁
