Dear Experts,
How can we enhance these scripts to get all the proper labels on every cases
Through DSM settings ?
analysis c:\Program_Files\Autodesk\AutoCAD_2019\ADVS\AstControls8x64.ocx
AT_LINE=11387
%%script
analysis c:\Program_Files\Autodesk\AutoCAD_2019\ADVS\Main.dll
AT_LINE=180212
%%script(If ("%StartX" = "%EndX" And "%StartY" = "%EndY") Or ("%EndX" = "") Then appendString("(%StartX/%StartY)") Else If "%StartX" = "" And "%EndX" <> "" Then appendString("%EndX/%EndY") Else appendString("(%StartX/%StartY)/(%EndX/%EndY)") End If)
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\AUS\Kernel\Data\AstorDetailsBase.mdf
AT_LINE=32521
Script1%%script(If("%StartX"="%EndX" And "%StartY"="%EndY")Or("%EndX"="") Then appendString("(%StartX/%StartY)") Else If "%StartX"="" And "%EndX"<>"" Then appendString("(%EndX/%EndY)") Else appendString("(%StartX/%StartY)/(%EndX/%EndY)") End If)DSCScript1Script1Script1Script1Script1
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\AUS\Kernel\Data\AstorProject.mdf
AT_LINE=15605
<Key>%%script(cutAngleX1 = getValueOfToken("IAngleX1"): cutAngleY1 = getValueOfToken("IAngleY1"): cutAngleX2 = getValueOfToken("IAngleX2"): cutAngleY2 = getValueOfToken("IAngleY2"): IF (Len(cutAngleX1)>0 or Len(cutAngleY1)>0 or Len(cutAngleX2)>0 or Len(cutAngleY2)>0 ) and (CDbl(cutAngleX1) >= 0.01 or CDbl(cutAngleY1) >= 0.01 or CDbl(cutAngleX2) >= 0.01 or CDbl(cutAngleY2) >= 0.01 ) Then appendString("Bev'd") Else appendString("") )</Key>
AT_LINE=15609
<Key>%%script(pLength = getValueOfToken("ILength"): pWidth = getValueOfToken("IWidth"): pContour = getValueOfToken("IContour"): IF 2*(CDbl(pWidth) + CDbl(pLength)) = CDbl(pContour) Then appendString("") Else appendString("CutPlate") )</Key>
AT_LINE=15613
<Key>%%script(iClass = getValueOfToken("IClass"):If iClass = "CoumpoundBeam" Then appendString("Compd"):End If:If iClass = "PolyBeam" Then appendString("Curve"):End If:If iClass = "BentBeam" Then appendString("Curve"):End If:If iClass = "Beam" Then cutAngleX1 = getValueOfToken("IAngleX1"):cutAngleY1 = getValueOfToken("IAngleY1"):cutAngleX2 = getValueOfToken("IAngleX2"):cutAngleY2 = getValueOfToken("IAngleY2"):If (Len(cutAngleX1)>0 or Len(cutAngleY1)>0 or Len(cutAngleX2)>0 or Len(cutAngleY2)>0) and (Abs(CDbl(cutAngleX1)) >= 0.01 or Abs(CDbl(cutAngleY1)) >= 0.01 or Abs(CDbl(cutAngleX2)) >= 0.01 or Abs(CDbl(cutAngleY2)) >= 0.01) Then appendString("Bevel") Else appendString("Exact"):End If:End If:If iClass = "Plate" Then pLength = Replace(getValueOfToken("ILength"),",",""):pWidth = Replace(getValueOfToken("IWidth"),",",""):pContour = Replace(getValueOfToken("IContour"),",",""):If 2*(CDbl(pWidth) + CDbl(pLength)) > CDbl(pContour) + 2 Then appendString("Bevel") Else appendString("Exact"):End If:End If:)</Key>
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\AUS\Steel\Data\AstorDetails.mdf
AT_LINE=28955
Shrunk LengthDSC#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)Schrumpfl
AT_LINE=28961
ceniaLongueur raccourcieShrunk Length#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)#Height(2.60)D
AT_LINE=28963
cia = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)Shrunk Length#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)Longitud de rebaje
AT_LINE=28965
#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)Shrunk Length#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)Shrunk Length#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)Zsugor
AT_LINE=28966
si hossz#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)
AT_LINE=28967
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\AUS\User2\Data\AstorAddIn.mdf
AT_LINE=30715
AT_LINE=30719
AT_LINE=30723
AT_LINE=43298
Shrunk LengthDSC#Height(2.60)Cut length = %%script(Cutlength = %Length-%ShrinkValue: appendstring cutlength)0
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\GBR\Kernel\Data\AstorDetailsBase.mdf
AT_LINE=32522
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\GBR\Kernel\Data\AstorProject.mdf
AT_LINE=15629
AT_LINE=15633
AT_LINE=15637
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\GBR\Steel\Data\AstorDetails.mdf
AT_LINE=39418
AT_LINE=39424
AT_LINE=39426
AT_LINE=39428
AT_LINE=39429
AT_LINE=39430
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\GBR\User2\Data\AstorAddIn.mdf
AT_LINE=40903
AT_LINE=49969
AT_LINE=49973
AT_LINE=49977
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\INT\Kernel\Data\AstorDetailsBase.mdf
AT_LINE=32419
analysis c:\ProgramData\Autodesk\Advance_Steel_2019\USA\Kernel\Data\AstorDetailsBase.mdf
AT_LINE=32760
Sanjoy Nath
BIM Manager And Digital Lead (Structures Online)
BOOST, AR , VR ,EPM,IFC API,PDF API , CAD API ,Revit API , Advance Steel API
Founder of Geometrifying Trigonometry(C)
