Hi @eyal.ch
You can add a 3D view to an existing drawing by selecting the assembly then running a 3D view based on selected drawing style
https://youtu.be/rd27YXhoWf0
If you want it to appear automatically then you will need to edit the drawing styles
Before editing or playing with anything make a backup of your Advnace Steel data - https://graitec.com/uk/blog/are-you-backing-up-your-advance-steel-data/
This article and video explain how
https://help.autodesk.com/view/ADSTPR/2023/ENU/?guid=GUID-B4BFB06F-395E-4252-8752-C53627CAFDBF
https://youtu.be/8nRAk7pR2HU
https://youtu.be/YxXHKPXAByw
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
