how do I change arrowhead for label with leader?
I want to insert a label on my drawing but, for this particular label, I wish to change the leader's arrowhead from "closed fillet" to "integral".
How can I do this?
When I edit the label, there is a tab for "leader line". There is a list of different styles in the pull down menu for the arrow style. Where can I create a style and make it appear in that list? I tried to do it in the prototype but that did not work.
Bogdan.O
To add or change the style for the leader's arrowhead you can do the following:
  • go to Dimension Syle Manager (or type DYMSTYLE in Command line);
  • chose an existing Style or create a new one. Then click Modify;
  • from the Symbols and Arrows Tab, choose Integral for the Leader;
  • Apply the changes and go back and use that Style for the Label.
Bogdan Orzea
QA Analyst
