I work in heavy industrial & use a lot of horizontal angle braces. I have a very common connection that is used a lot, and is actually detailed in our standard details sheets where two beams, an angle brace, and a column intersect (see screenshot). I need the brace connection to not interfere with the beam to column connections. I need to make this in the model time and time again and I'm not finding a connection even close in the library. I have created this and tried to turn it into a custom connection. I get the blue custom connection box but if I try to insert it at another location it just doesn't work. Also, the angle of the brace coming into the intersection may vary considerably so it would be real nice to have it work by just clicking beams involved.
