Hide bend line of Folded Beam in Detail View
Julio_Soto
Advisor Advisor
Julio_Soto
I have the presentation for Folded Beams set to "VissibleHidden" but it still shows the bend lines. I do have the box checked in the MT to hide the lines, but nothing. Very frustrating!
Sebastian_Eiche
this is not the folded line itself, this is the start of the folding radius. This is a conturline and as I know this could not be deleted.
It like a specialpart, the edges of the solid are always shown, and here it's a bit similar. If you explode the folded element, you will see these lines, because they are needed to create the body.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Julio_Soto
I was afraid of this.  I think the folded beam command is fantastic. But then I had to create detail for it and now I see those lines. This can make a part a little busy, especially if there is a lot more going on with the part. I suppose I could a custom profile, but it was just so easy to make a folded beam ;). It breaks my heart that I wont be able to use that feature ;(
