Help with Creating Large Diameter Pile Profiles
rmoutonJ6JSY
rmoutonJ6JSY
I am trying to create a new database for large-diameter pipe.  Imperial sizes up to 96 inch. Deciphering the columns and the formulas in the MDF has been a challenge. Is there a resource that explains what they are and even better what are the formulas to get the numbers?  I spent over an hour trying to figure out the formula for U(Lateral surface)
StandardNameSectionNameStandardsReservedOwnerTextParameter1Parameter2A(F)AreaEX(ex)EY(ex)U(Lateral surface)
johnjmbennett
There are several videos and faqs over this,
try this one, may help
https://youtu.be/sPPxQfN8F0E
to find an area of a section, you can use the autocad commands to create a region and then list the properties of that region.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU/AutoC...
cheers
John Bennett
