[help] Camber beam details
I’m working for the first time with cambered beams on advance steel.
I’ve modelled the structure, defined the beams as cambered and set the amount of camber required for each one.
My problems began when I tried to create the part/assembly details for such beams has I found that I can only create one type of drawing for this kind of beam (print attached).
The factory is used to have a part detail, where cuts, holes are presented and an assembly detail. Therefor is there any way of making a part detail where only the beam is displayed?
In the detail attached the attached parts are only displayed on the front view. In this view the upper flange has 7630 mm of length but in reality, after camber, it will have 7634 mm. This difference will make the shear connector and stiffeners out of place (the difference on this beam is almost nothing but on others beams is not). Therefore, is any way of presenting the attached parts on a view with camber geometry?
