Hatch on drawings
Hatch on drawings
Upon editing detail drawings I canot figure out how the hatch command works.
I canot get patterns just solid colors?
Dias_Antonio
Hi
I think you need to export to AutoCAD and perform the command there
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
muleman1
@Anonymous use the search box for this forum, enter hatch and you will see many post about hatch. It is much tricky than reg autocad to use. maybe even buggy
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
muleman1
@Anonymous another thing is sometimes I see solid hatches because of the hatch scale. sometimes i have to set hatch scale to .01 or .001 or even .0001 to get it to work.
bukko
As far as the autocad hatch command and manually adding a hatch
When changing the scale of the hatch doesn't seem to work for you and you're still getting solid colors a technique that works for me everytime  to correct the sold color problem is to reset the origin of the hatch to a corner or snap point of the object.  You have to be able to highlight the hatch and then right click for the drop down and choose " set origin"  As long as you can select the hatch you can change the scale and set the origin.
This will fix your problem in 99% of the cases you'll see.
Regards
Craig
ECMS
