handrail split in two?
For some reason my handrail split in two? no sure how, I've attached an image, I can attach a drawing file if need be.
Tim
acbsdesign
This is because the railing was built by selecting two different beams.
If you need it as one railing, create a dummy beam first.
Explode the macro, delete the dummy beam, and add the two beams to the connections.
HTH
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
I wonder why it worked on the other side then? two different beams, a W6 and a C6.
acbsdesign
'Use of poly beams' may give you a continuous top rail. Probably your macro is done this way.
(Not the midrail though)
