Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
guardrail - angle at the beginning
3 REPLIES 3
ab82D38
153 Views, 3 Replies
Hello everyone,
I'm trying to draw this kind of guardrail but i don't manage to realize the beginning as the hand drawing below (dimension here below not important, just to explain principle).
Does anyone have an idea of how to do it properly ? With curved tubes welded,...
Thank you in advance for your help
Labels (1)
3 REPLIES 3
Doesn't look like the OOTB macro does this so I'd guess you'd have to add them in yourself, and weld them to the rails.
Jason.RyanRJXE4
in reply to: ab82D38
Place the pipe or member you're using along your construction lines. Next go to the "Connection vault" under the Miscellaneous tab (icon looks like an open web steel joist) click on "railing joint".  From there you can specify what type of joint you want.
ab82D38
in reply to: Jason.RyanRJXE4
thanks a lot it worked perfectly
