Grids Advance Properties Greyed Out
JeremyOakes
JeremyOakes
Any ideas why the Advance Properties are greyed out on these grids? If I create new grids I am able to access the Advance Properties.
johnjmbennett
If using projected grid, try selecting the grid at the base only.
John Bennett
JeremyOakes
@johnjmbennett Thank you for the reply. I am not sure if this solved my issue but somewhere along the line while working I was able to get the option.
Sorry for those in the future looking at this. I don't know what did it. Hopefully it was @johnjmbennett suggestion.
SabinaK4RXQ
I have the same problem. I tried to activate just base and then to modify grids, but Advanced option keeps to be grayed out. What else can I do? Thank you!
D_Waeldele
If you have layers enabled, changes are not possible. If you have layers disabled, you can change the grid.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
SabinaK4RXQ
Hi @D_Waeldele
Thank you for your time to give your answer.
I tested your answer on an existing project with layers either enabled or disabled, and now I can see Advance Properties option is active either way. I don't understand what has changed, but for sure I will come across this problem again and I would like to understand what is happening.
