grid
grid
I am very  new for advance steel
First time I used advance steel, I cant figure out how to build multy story building
I learn to utilize add level above the building in project manager so I solve that problem
But I have another problem,
When I am working second or third level, I cant see the grid I put in the ground
Even I activated level 0, and still Grid disapper
it should be something which allow the grid seen at all level
Even I copy the grid in level 0 to 2nd level, when I activate level 2, still grid disappear
múinteoir
When using levels its effectively using a view range to control what you will see. There is an option if you right click the level to show the model view box. This can be strecthed with the grips to change the view range of the level.
You could also assign the grid to a layer and control visability that way without using levels.
The face of the BIM game | Former Autodesk Expert Elite | YouTuber | Lego Builder | Monaghan Man | Some Can, Some Cant
Unfortunately, I tried what you commnet, unsuccessful
Are there anyway to use original set of grid at all levels
