Framing Plans with incorrect information
advandes
Advisor Advisor
advandes
Using AS 2019
Thank you for reviewing my post. Please also refer to the attached screen capture.
This Framing plan was generating using Drawing Process "Selected Camera page Full"
I have two issues here:
1) The [-2'-7 3/8"] is coming from somewhere and should be read from 0'-0" which would be +13-4", so this needs to either be removed from the tags or corrected on all the Beam Size tags. It would be my preference to remove it.
2) Two of the beams are noted [Sloped] and this is totally incorrect. I have checked these and they are not sloped. Any idea why this is happening?
AAG
Advance Design
olivier_gervais
Hello Advandes,
THe -2'... is from the UCS when you created your plan view. so if your plaview look at everything that is 4' beloy the XY plan, it will detect these beams which are located 2'... below the XY plan. So yes, if you do not want to see it, it will need to be remove from the label strategy. this value was intend to be use for Roof plan when you gave Joist Seat which are most of the time -4" from TOS.
For the second portion of your question, if it say sloped, even if it is a 1/16" it will show sloped from the XY plan of your view.
