Formula in Summary in External BOM
Bertievz
Bertievz
In our external BOM lists, we have a column for paint area, but we don't want the paint area of Grating objects to be included.  I was able to use a conditional statement to show all individual Grating parts areas as zero, while still showing the correct areas for other parts.
But.. in the summary and the total at the bottom, it still adds up all the areas including grating.  How do I tell it to only sum the non-grating items?
bigcarl5000kg
create separate BOM for gratings only
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Bertievz
Okay, I had a suspicion that we would be forced to use separate lists, but I was hoping that there was another way. Thank you.
Sebastian_Eiche
As another idea:don't use the paintarea to be shown. Maybe you instead of this you use a formula: quantityxpaintarea and in the groupheader you summarize the formula itself.
So if you use qunatityxpaintarea and the paintarea is zero, the result should be zero and therefore the summarize should correct (but look not good by having so much "zero" in it).
I would also prefer to use to different lists
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Bertievz
Thank you.  I don't have a very good understanding of how the summarize fields work and how to apply formulas to them, but I will try and see if I can get it to work.
Bertievz
Can you tell me how to summarize the formula itself in the groupheader? Currently the groupheader's field is "../MUnitPaint" but what does that mean? How do you tell it what to add together in the group header and also in the total at the bottom?
In the detail section, I had to type my conditional statement directly in the Datafield box, so I don't know if I can refer to that formula again in the group header.
I have looked and searched everywhere for information but can't find any documentation or help on this part of the BOM editor.
