Fillet Weld assigned to Layer Zero
zirudezirude
zirudezirude
Hi Guys,
Is the any way to automatically assign Fillet Weld symbol to its own layer instead layer zero, which create an issue when Xref the file, I mean by that layer Zero will disappear when you Xref a file and will be merged to the Xref Layer so you cannot control it in the file that host the Xref.
Jonathan3891
There is a general weld layer, which should be set as default.
Did you by chance the settings?
Management Tools > Defualts > Layer Assignment
Jonathan Norton
Blog | Linkedin
j.hamelin
AND you MUST be on "Standard" layer while adding weld or anything else macro controlled to proper get the default assignated layer.
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
zirudezirude
Thanks @Jonathan3891  for the quick reply,
In the management tools the layer is assigned to "Welds", But I did not see the layer "Standard" in layer manager, is there any reason for that?
zirudezirude
Thanks @Jonathan3891  and @j.hamelin  for the quick reply,
Jonathan3891
Take a look at this layer assignment
Jonathan Norton
Blog | Linkedin
j.hamelin
Type a product name
