So now that I can get the file name and drawing number in the title block to be generated how I want them for assembly drawings using drawing processes can the same be done for drawing styles?
Solved by Sebastian_Eiche. Go to Solution.
Do you know this default:
Drawing Styles:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Wow, didn't know that one.👍
Thanks @Sebastian_Eiche.
Works like a charm.
