External BoM Scripting
Julio_Soto
Advisor Advisor
Message 1 of 15
Julio_Soto
I found this AKN page regarding scripting in an external bom.  It seems to be lacking alot of information. Or I guess it's possible you can only do what is shown on this page.
Does anyone have a more thorough document about scripting for an external bom?
link to the page
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
Replies (14)
Message 2 of 15
Sebastian_Eiche
There's no other documentation to this as I know.
Here in the forum are a few threads but not much.
Some c# classes could be used and some not I never find a doc which are working.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 3 of 15
bigcarl5000kg
Hi @Julio_Soto,
you may first have to study several available materials for scripts, then it can be applied to certain tasks ...
I know that there are not as many of them as one would like, but do not expect surprises.
Here is a tasting ...
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Message 4 of 15
Julio_Soto
Thanks for this, It's not what I was looking for but it is still useful for other stuff.
I was specifically asking for scripting inside the external BOM.  I never would've guessed at the operators.
For example, "=" is "==", and the "if" is noted by "?". I never would've figured this out.  Is it possible to use an and/or statement? I have no idea what symbol/syntax I would use.
Message 5 of 15
Sebastian_Eiche
This is a reference used by c#.
condition ? consequent : alternative
The script language could be changed in the bom editor, but I never tried it. If you select the template there's an option for Script language between c# and vb
Sebastian Eiche
Message 6 of 15
Julio_Soto
ah, I see. That's very helpful. I don't know C# but I can learn ;).  Thanks!
Message 7 of 15
bigcarl5000kg
Hi @Julio_Soto ,
have you made any progress? Can you give us some results? Thank you in advance and have a nice weekend.
Message 8 of 15
Julio_Soto
I have made some progress. I googled C# scripting examples and then just started experimenting.  Here are a few I did that work.
=(ILength==null)?(""):(((IName.Contains("ISO")|(IName.Contains("DIN"))?(ILength + " mm"):(ILength))))
The "Contains" is what I use instead of wildcard asterik.  For example, you can't say IName="*ISO*".  You have to use the Contains method. This was incredibly useful for us. Our company always uses metric and imperial. However the External BoM formats units for the entire bom.  This makes it tricky for us. Our ISO/DIN Bolts length always show up in inches.  So I wrote the above script to check for DIN or ISO and then add mm to the length. THE "|" is C# version of "OR"
Something else I learned, if you use some measurement token (e.g. IWidth or ILength) , in a script, it will always return the value in mm. It doesn't matter how the Unit Properties of your BoM are setup.  To get around this I had to use Template Mapping to create a custom External BoM Tokens that format the value as I need. See SS below.
This mostly worked.  I ran into a problm if the Custom Token was nested in an IF statement. If the custom token is used in an IF statement that is nested in another IF statement the BoM returns null or a "True", "False" value. It's weird and I cant explain it.  If it's in the top level IF statement the custom token works.  AS is weird. Below is that script
=IName.Contains("Bent") | IClass.Contains("Nut") | IClass.Contains("Washer")?(IName.Contains("Bent")?"TBD":""):XXXLengthUS
The easiest script I wrote I used to to get around AS's bug regarding mapping for folded beams. It was confirmed by AutoDesk that mapping for folded beams does not work as intended.  AS will correctly map the folded beam. The problem is, for reasons unknown, IExternal1 does NOT replace IName as it does for all other mapping items. So below I did a check if IExternal1 is blank, then use IName, otherwise External1. Works perfectly
=IExternal1 = ""?IName:IExternal1
Message 9 of 15
bigcarl5000kg
Thank you for the feedback
Message 10 of 15
niels.h
I would like my fittings list to only have the part marks and not the main marks.
Maybe you can help me out with this?
=(IPNum != MNum) ? (IPNum)
Message 11 of 15
AleckGiles
Hi @niels.h
Just change the token used in the field to Single Part Mark instead of Part Mark. Part Mark calls up the assembly number for main parts and single part number for attached parts. Single Part Mark always uses the single part number.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
Message 12 of 15
Flies-Eyes
Oh dear..... looks like I have another steep learning curve in front of me to achieve some basic filtering.  I suppose if I never get started, I will never get finished.
Thanks for sharing your findings.
Message 13 of 15
Julio_Soto
it's actually not that steep, but only because it is pretty limited in what it can do.
Message 14 of 15
JAANWLODARCZYK
Community Visitor
Community Visitor
But where do you input those scripts? Do you define it in "formula" cell?
Message 15 of 15
Julio_Soto
In the DataField cell
