External BOM Editor can not save the change.
arkli2009
arkli2009
Also can not create new BOM template.
Details style after modification, the list will turn to empty.
Need some help.
Thanks in advance.
Replies (12)
acbsdesign
@arkli2009
If you copy an existing box in an External list, and  it won't change the field content, it will not change after save, you have to create a new text box, modify the field content, and save:
Create new box and saveCreate new box and save
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
arkli2009
Thanks your reply.
I noticed this issue before.
But this time, my BOM can not save at all, even delete a box from the template. Save doesn't work at all. Also can not import a new template in.
(I am using 2017.1, and I copy the data file multiple times, and switched computers ... , all the rest computers work fine, only the one I use most got the issue.) (I am guessing 50% my fault, 50% windows 10 updating's fault. :-D)
Hope someone got the same issue like mine, and has a quick fix.
AleckGiles
This may be obvious but it is always worth checking Smiley Happy ....
You are working under the User folder I presume. The Advance folder is locked and users cannot make changes to anything in those folders.
Aleck Giles, Structures Consultant, Graitec
LinkedIn
Autodesk Certified Instructor - Gold
arkli2009
Thanks for you reply.
Actually I found the problems, which is my data file is way too big, due to all the learning bugs. After I use "access" fix and optimize the data file, everything turn back to normal (and running better).
So I am not sure this should be a standard fix process for people who has problems with AS.
muleman1
@acbsdesign  how do you apply borders to the text box. I so embarrassed, I have been working for 45 min trying to change this header from inches to decimal feet, then I came across this thread.  Is AS by design to be so complicated , screaming difficult to do the seemingly most simple things..????  To this ignorant, uneducated redneck, it boggles the mind why you wouldn't be able to simply change the txt in a header and move on in 30 seconds....
....How easy it is to acquire knowledge, yet how difficult and painstaking is the process of gaining wisdom. .... Chuck Swindoll
acbsdesign
@muleman1
Hi, It is the way Advance Steel External lists are done.
Right click on the box, "format border".
If you try to change the text within existing box it will revert to its original text, it does not accept changes.  You need to create a new box, and modify "field content" with right click.
@acbsdesign wrote:
@muleman1
Just to be more precise, I would like to share what I found out about the issue of not being able to update the TextBox field contents when you want to customize your headers or footers or whatever else...
If you take a carefull look to the right pane ...
Capturar.JPGYou see the Tag content...with a reference to some external data...in this case it is calling for BOM,1....
Now...go to Management Tools, Table Editor and open the database stored at...
\ProgramData\Autodesk\Advance Steel 2019\INT\Steel\Data called..."AstCrtlDb"
Open up the subtable "ErrorMessages" (I wonder why Advance Steel developers had used this table to save this type of information...)...it will show...
So...%%Text(BOM, 1) is "reading" the BOM prompt with ErrorNumber 1 that corresponds to the ErrorText "Mark"...so...one way to update this label on ALL the BOM templates...and I mean ALL of them  is to simply change here this label...this will affect all future BOM external lists where this text Mark is shown....if you look down this table you see some oher familiar BOM texts...
This is not however what is normally our intention...when all we want is simply to get an user list for example in our native language or instead of "Mark" just say "Piece Mark" or whatever else...
The way to do it, without needing to erase and create new TextBoxes is simply deleting the Tag content on the right pane and then change the FieldContent to what you want to use...and save it...if you keep the Tag content as it was...then next time you open it, the system looks on the database again and it writes what is there recorded...if the Tag is empty than there is nothing to look over...and the field content is kept! This way you keep the original texts as you may need to use them in the future and customize your own BOM in an easier way...
Please note that when you create a new textbox the Tag field is empty...and this is the reason why it works also...but in a more "difficult" way as you need to adjust the textbox size and format to keep the original look.
Hope this helps...
But developers...calling this Prompts....ErrorTexts is somehow a little odd!!
muleman1
Thanks for the replies. It is still so complicated its wastes so much of my time we have learned to just go with the out of the box and change our ways to fit the insane manner AS does things. We have come to the conclusion that AS is designed by politicians......regular thinking detailers could never imagaine something so complicated and user unfriendly....
Good grief, would have NEVER thought to look there, thanks a bunch
johnjmbennett
you can just remove the tag entry , then set the field content to the token required , or just plain text field required, using that option.
the cells can be set to have just text, tokens or formulae as required.
if you create a page header section in one template, you can select it and copy to another, as with the other elements, but you should watch which template you start from, as each type has some element in the xml code to control how it functions ,  this is why there are Assembly type lists, plain materials lists, etc.
Cheers
JB
John Bennett
advandes
You nailed this comment. I was just reading through this thread because I have the same problem trying to edit a BOM. I just wanted to change the heading to add my company name, and I can't get it to save. I then read through this thread and was more confused than when I started. The answer for this problem should be in a one sentence statement. Export to excel and edit it there... ugh!
AAG
Advance Design
Garret_H
Evergeen quote right here. I'm trying to edit lists and hitting roadblocks everywhere because this feature doesn't behave like anything else.
F_ck this software.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
