External BOM - Bolts/Anchor Summary list - Nuts & Washer listed twice
Good Morning,
we are working on our template for external BOM summary bolt & anchor list (sort of shopping list).
We started started with default UK-Bolt & Anchor list.
When we created the list we have noticed that M20 Nuts and Washer are listed twice: firstly the quantity of all Nuts and washers in Bolt Assembly and then for the second time quantity of M20 Nuts and Washers in Anchor Assembly.
These nuts and washer are identical (Coating, Grade, Dia,...., we also checked the database and the same nuts & washers are used for bolt assy and anchor assy ). Is there any way how to create a total count of elements regardless the type of fixing they are used in? Meaning that we would have just one record of M20 Nuts containing quantity of these nuts used for Bolt assembly and also Anchor assembly?
Please see attached pictures showing the template we use to produce the list and then the produced list itself.
-we have also tried to remove GroupHeader completely from the report but with no result.
Thank you in advance
Ondrej
