Exploding to CAD dwg
bageseabraham
bageseabraham
I am having an issue with exploding detail drawings to CAD drawing. All the sections come with the same layer from AS model except the grating. Is there a way to fix this? I had a look on explode settings, but the beam & grating had the same configuration (explode with the same layer).
Abraham
johnjmbennett
There is settings under the explode options to configure, it goes back to a database table.
From memory think there is a setting in Management tools to use explode settings .
If you are using 2017 onwards, there is the opition to install the ADvance steel object enabler, on the machine you wish to view the drawings and if they have autocad or autocad LT, then you can view the drawings without need to explode.
John Bennett
bageseabraham
Thanks for the response.
Is there any videos or webinars for the explode settings?
johnjmbennett
Try these links
http://www.graitec.com/en/FAQ_view.asp?FAQID=479&Language=EN
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2016/ENU...
John Bennett
bageseabraham
Thanks, much appreciated.
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @bageseabraham,
Thank you for using Advance Steel forum 🙂
There is a known issue with the explode details to AutoCAD for gratings, that the option "Same as detail" will place the grating lines on the layer "0".
This behavior is documented and sent to the development team for further investigations.
As solution for now, you could set the explode layer for grating to a specific one (like "Gratings" for example), instead of using the option "Same as detail"
You might find helpful also this article:
I hope this will help you
Best regards,
Emy
Emy Nestor
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
