Error code 223
Error code 223
Rushiayarekar
Error code 223
Rushiayarekar
Hello everyone,
In the audit window i found error 223,  showing beam body can't be calculated - notch removes the entire object. Please help me what to do now?
Sebastian_Eiche
First: if you add the tags and use my name, this will not mentioned me. This tags are used if someone insert this in the forum Search, and I think noone will search for me 😁
To you problem: you create a beam and insert a shortening which 'shorten' the whole beam. For example you have a beam with a length of 1000mm and insert a shortening with the setting of 1100mm.
This problem should be solved by using the model check.
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
