End plate Connection to concrete Beam/Column
alexborodulin2
alexborodulin2
What is the best way to add end plate anchored to conc. column/beam? I didn't find appropriate macro.
Thank you,
Alex Borodulin
robertwmerriman1
Hi @alexborodulin2
You could use the Base Plate macro, this will work on a beam whether vertical or horizontal.
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
alexborodulin2
...So simple. Thank you, Rob.
The only small problem: how to add more available lengths of bolts in combobox.
Thank you,
Alex Borodulin
robertwmerriman1
Hi @alexborodulin2
You would need to add the extra anchor lengths via the management tools, its a bit of work, here is an Autodesk video running through the process - https://www.youtube.com/watch?v=gGCvrv2vIVM&list=PLY-ggSrSwbZr_DW0ssM7B20FqEvhoCnjq&index=3&t=0s
I would strongly advise before you modify anything that you back up your data, see my blog on the subject here - https://graitec.co.uk/blog/entry/are-you-backing-up-your-advance-steel-data
alexborodulin2
Good, Thank you, Rob.
Alex Borodulin
