Edit Stair Start Point
advandes
Advisor Advisor
advandes
Advance Steel 2024
I have a client who has requested many changes to a custom multi-level stair, and now they want to move the bottom tread up and eliminate the first tread flush with the floor as shown in the attached screen capture, but I don't see a way to do this in the macro or a "grip point" in the model. Anyone have any ideas here? Appreciate any help!
BTW.. I know by changing the stair rise/run will completely mess up the railings, so they will most likely have to be recreated.
AAG
Advance Design
mick-CNF
If it is the standard AS stair macro go into wireframe and there should be a white box which you can drag from the corners.
If this information solves your problem please accept as a solution.
mick-CNF
advandes
Thanks Mick... It worked.. I guess I never noticed that box before.
AAG
Advance Design
