I have the following issue - I use default Drawing process templates to run my assembly drawings. As result I get my assembly with default label and some dimensions. I want to change the style of all labels in the Assembly drawing - for example, instead of receiving only part number, I want to change label strategy to <part number>+<name ( specification of element)>. Is that possible? If not how can I change default label strategies for Drawing process templates(I want to generate all assemblies in separate sheets).
Other issue that I have is that I have to generate 3D views for every assembly(in separate drawings). I know how to add the 3D view in the drawing after the generation(but this is one by one). My question is can this be done automaticlaly by Drawing process templates - "All assemblies - one per sheet"?
Any help would be appreciated.
Thank you in advance.
Ivaylo
