DXF Font
troy56VYU
DXF Font
troy56VYU
Can someone please tell me how to change the font of the single part numbering annotation in the DXF outputs. I've tried loads of different things but basically I cant use the default font as it creates a double line in the nesting software we use. I have a font that works but I cant figure out how to make the output use the font I want. I've changed the text styles but the dxf output doesn't seem to use the same drawing template, so I changed all the other templates available to me that I don't use and still nothing is working. I have looked everywhere in the settings and cant find anything there either.
Please help
Dias_Antonio
@troy56VYU
By the way, did you follow these steps?
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/Advance-Steel-How-...
I hope it works
- Marque "Aceitar como Solução", caso tenha resolvido seu problema.
- Select "Accept as Solution", if it has soplved the problem.
- Clique em "Curtir" se a resposta ajudou.
- Click on "like" if the answer helped.
Antonio Dias
|Linkedin|Instagram|Facebook|Twitter|YouTube|
Colaborador da Comunidade de Usuários Autodesk Brasil
troy56VYU
Hi @Dias_Antonio,
Thank you for responding. Unless the numeration tag is considered a dimension this doesn't seem to have worked unfortunately. I'm not too sure how changing the prototype for drawings will help here, does the dxf output use the prototypes?
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @troy56VYU,
Thank you for posting on the Advance Steel forum 🙂
I understand you want to change the default font for the texts inside DXF files generated by Advance Steel.
The DXF files are started from a "No template" drawing (pure AutoCAD). There is no option to set the text style or font.
The text style is "Standard" and the font "txt.shx", hard-coded.
What you could do is change the font of the "Standard" text style after generating the DXF file. Then it is saved inside the file.
If you have many DXf files, maybe you might consider writing a script or routine, to automate setting the font for multiple files in one step. (you could check this thread: Change All font in Text Style Manager).
Hope it helps 🙂
Best regards,
Emy
Emy Nestor
troy56VYU
Hi @Emanuel.Nestor,
Thanks for for your help. I've tried to use the codes from that thread as commands in the software but to no effect. Not entirely sure if I'm doing that right, I know basically nothing about code. I then tried to look for the "no template" pure autocad file like you mention but it turns out I don't have one. I might have messed up the original by over writing it with the custom template I created for myself, big oops on my part. Is there somewhere I can get a fresh copy of this template? If I can, do I just need to put that file into the templates folder to work? Finally, am I able to modify this template to use the specific font I want or is it more complicated than that? You mentioned hard coding which is way over my head in terms of me being able to adjust this.
Thanks again for your help, its very much appreciated.
Regards
Troy
PS, if I don't have a no template file, how are my dxf's getting the standard font?
Emanuel.Nestor
Autodesk Support
Autodesk Support
Hi @troy56VYU,
Thank you for your reply.
When I mentioned "started from a no template drawing" I was referring to that option from AutoCAD to create a new drawing without using any template at all:
In this situation, the drawing is created using hard-coded settings, not settings stored in a file or template.
So there is nothing you could have overwritten here 🙂
But it also means you cannot change the default (hard-coded) settings for text style and font. The DWF files are created with that particular text style and text font, no matter what.
The only way to change them is to modify the DWF file after it is generated. Manually in each DXF file, or using some automation (indeed, programming knowledge is needed for this one, sorry about that).
Hope it helps 🙂
Emy
Emy Nestor
troy56VYU
Hi @Emanuel.Nestor,
Thanks again for your help. Hopefully we get an option to change the font in future versions of the software. Seems like it wouldn't be too hard to implement, maybe I will have to dip my toes into the world of programming to see.
Cheers
Troy
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
