Drawing title block information
advandes
Advisor Advisor
Message 1 of 13
advandes
Using Advance Steel 2019
Thabks for reviewing my post.
Question: Do you have to manually fill out each title block of every sheet once they have been created? It seems crazy to me that this can’t be set up prior to creating drawings so that the project information is automatically filled out. Help with this would be very much appreciated
AAG
Advance Design
Replies (12)
Message 2 of 13
johnjmbennett
in the model, you need to use the “project settings” button , it’s on the home tab of the ribbon towards the right,  fill in the fields under the first two tabs, and there is also a tab at the end for user project attributes.
https://knowledge.autodesk.com/support/advance-steel/getting-started/caas/CloudHelp/cloudhelp/2018/ENU/AdvSteel-GetStarted/files/GUID-52AC1094-F73B-4DB5-81B9-328E7A862D5B-htm.html
the prototype page header block header, will have be set up to receive the data from the model project settings, using tokens /attributes .   It should filter through.
Also if you have already created the drawings, you can still enter the information under project settings, the use the update page header button, on the label and dimensions tab, there is a little fly out at the bottom of the first panel on the ribbon.
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU/AdvSteel-Drawings/files/GUID-57E3D83D-A4A0-44D2-A120-59735C54E6B3-htm.html
cheers
@johnjmbennett - This reply has been edited by the moderation team as the legacy links were no longer valid
John Bennett
Message 3 of 13
Sebastian_Eiche
For sure we don't fill it manual. In the start tab right side near to the management tools button, you have the project settings. Here you could fill all attribute which could be filled automatically.
In the dialogue in the end there are a few extra userattribute.
There's a knowledge base article belonging to the prototype article which token are available and could be used in the title block
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Message 4 of 13
I have a question. I have a block defined already with attributes. Is it possible to define another block in the template that can also be updated automatically?
I don't know if user defined attributes token can be manipulated for this purpose
Message 5 of 13
Sebastian_Eiche
As I know the token are only working if they are part of the HYPERSTEELPAGEHEADER, but why not including the token to this block but move them to place you want (on the place, where your other block is located) by creating the Hypersteelpageheader block
Sebastian Eiche
Message 6 of 13
Yeah, but all the tokens are already assigned in the block previously created. For the new block (or the same block with Extended rows and columns) would I not need new attributes token?
Message 7 of 13
Sebastian_Eiche
there are only a few attributes, which could be included or better "get filled" from the model, and yes you have to recreate the block.
available attributes
Sebastian Eiche
Message 8 of 13
Can the user attributes i.e USERATTR1 be updated from the model?
Message 9 of 13
Sebastian_Eiche
please press on the link I created in the last post, and you will see all available token...
Sebastian Eiche
Message 10 of 13
Hi, @johnjmbennett
that button Isn't working for me, this message keeps popping up 'This command only applies to model DWGs'
even thought I've updated my models project settings and have both model & drawing open.
please see attached pdf & prototype. Am i doing something wrong?
This was not the first incounter. My other projects are the same, just getting frustrated with it now cause this job has hundreds of drawings....
I am using AS2020
Kind Regards,
Kiet
Message 11 of 13
mick-CNF
You need to use update page header when in model space, not in a 2D drawing.
I'm not sure but you should probably close any 2D drawings associated with the model that are open.
It should update all the drawings you have in DM.
If this information solves your problem please accept as a solution.
Message 12 of 13
@mick-CNF Thank you!, that was something I didn't think to try. I kept reading similar things but was thinking I needed the actual 2d drawing open along with the model. But really I just needed the model open and not the drawing.
Message 13 of 13
johnjmbennett
this is the AKN help page on this process, you must be in the model DWG.
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU...
John Bennett
