Drawing Style Manager Hidden Lines
suesLPLV6
suesLPLV6
I'm trying to modify some of my drawing styles and have come across an issue where my hidden elements are not shown in the front view of the attached beam.  The hidden elements are shown in the bottom view but not the top and the section does not include the cross section of the beam.  See the attached images.
Replies (7)
Sebastian_Eiche
It's hard to find the problem without the detail style itself.
What style do you use before you start to change things? Does it all work with the style? I mean the cross section looks like the line is missing for Exact view:
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
suesLPLV6
I'm using the 5 - Beam Style and when upgrading from 2018 to 2019 my settings didn't migrate properly so I'm using another user's settings.
Sebastian_Eiche
do you try to use the original styles? maybe the AstorDetails is broken, which includes the original styles.
Sebastian Eiche
suesLPLV6
It does appear when I use the Advance Steel - 5 - Beam.
suesLPLV6
Thanks Sebastian for the assistance I decided to create a new style instead of attempting to fix the existing one.
Sebastian_Eiche
I know this is often not what a user want to hear, but I often advise this...
Before taking time to find a way to get something work what is definitely not working correct, it's often faster to go 2 steps back and do it again. But I learn in the last few years in this forum, that this is not what the users want to hear 😃
Sebastian Eiche
suesLPLV6
I hear you.  🙂  I did start over which resolved the issue but sometimes I try to find the "fix" in order to expand my knowledge.
