Is it possible for the drawing name to be the same as the part number.
For Example: p1001 is the part number. So I want the drawing name to be automated the same.
Thank you.
Solved by johnjmbennett. Go to Solution.
John Bennett
John Bennett
I am no expert in this area but I will help where I can. I'm sure @johnjmbennett will explain more clearly.
As john said in the previous post. This Is controlled by the file name selector - reference token, in the file name selector in the drawing process manager. You will have to modify the drawing name to include Part No.
There are a few threads on this forum which you might find useful.
Hope that helps.
John Bennett
Thanks for your help.
This is what I got before. Is there anything I missed?
John Bennett
This video by kirk should help, around 6 minutes on, there are also other videos you will see related to this on you tube.
