Document Manager
Document Manager
josearturlinhares
Document Manager
josearturlinhares
Sirs,
I just finished a strucutural model using Adavance Steel 2024 and in the Document Manager there are 60 details drawings. Really there are only 59 drawings, because the detail with the number 28 exist but I cannot find where is it.How I can delete this number from the details list?
Jonathan3891
Does detail 28 show up in document manager?
If so, open document manager right click on the detail and select delete.
Jonathan Norton
Blog | Linkedin
josearturlinhares
Jonathan,
No, the drawing 28 is not in the Document Manager. My model contain 59 drawings and when I wanted to rename drawing number of 60 to 28, the answer was that this  number  exists.
Jonathan3891
In document manager right click on a drawing and select "Rename Drawing Number".
Jonathan Norton
Blog | Linkedin
josearturlinhares
Jonathan,
I want to change the drawing number 60 in number 28, but this is impossible because the drawing with number 28 already exist and I cannot delete it because I do not know where the file is.
Lewk_PSB
Check in "Unknown".
If drawing 28 isn't in there, go to the project folder and in the "Details" folder will be all of the drawings. Likely drawing 28 is still in there but it's not "registered" correctly, so you just need to simply delete it from the folder. After that, you'll be able to rename drawing 60 to drawing 28.
The Document Manager is PERFECTION! Glad they never changed a single thing about it since 2008! 🙄
