Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Dimensions missing
2 REPLIES 2
larry_spatz
221 Views, 2 Replies
Dimensions missing
I have quite a few dimensions that are missing from my drawings and mainly where I have holes located, after I create
my shop drawings. I have attached a couple of snap shots as to what is going on and was wondering if someone could possibly point me in the right direction is getting this corrected. Thanks!
2 REPLIES 2
Flies-Eyes
in reply to: larry_spatz
Without knowing all the history, I can only take a stab in the dark.  It seems no dimensioning has been included in the Top and Bottom views, and the Front View may only be set to dimension visible holes.
If you are new to AdS, tackling dimension customisation will not be an easy topic.
bigcarl5000kg
Hi @larry_spatz ,
can you post here some example from model and drawing data? Are your drawings style set up correctly?
+++ impossible immediately and miracles within 3 days +++
+++ the only constant is the change +++ stay tuned for more +++
+++ since 03/2023 is Advance Steel in maintenance mode, no further development +++
Technology Administrators
