Detail Style Maps - Grating & Material
Flies-Eyes
Advisor Advisor
Flies-Eyes
I am doing some more testing of my AdS 2023 version. Below is the code that I wrote to filter in the Detail Style Map the selection for object type Grating and the material type Grating_MS, however it doesn’t seem to be working.  Seeking assistance with my
my error/s?
_________________________________________
'Check Grating StandardPart and Material Grating MS
Function checkElement(Obj)
    checkElement = False
    If Obj.Type = kPlateClass OR Obj.Type = kGratingClass Then
        If Obj.WasDetectedAsSPFromStandardPart Then
                              If InStr(Obj.Material, "Grating_MS") > 0 Then
                                        checkElement = True
End Function
____________________________________________________________
Buxtehude1963
Flies-Eyes
Thanks for that. I have read these in past however I will go through them again to see if I can find the answer or work out the answer. It is probably just a simple mistake that I am missing.
