so before you do anything, you can look for program data under your computer, if you cannot see this folder then enable hidden files and folders via windows explorer.
the goto program data, then autodesk folder, then look for the advance steel with version number and you can copy the whole of that folder, in that you have every data base.
also there is a folder called advance, copy that.
place those folders else where.
within the advance steel folder there is a number of folders, the one with the astoraddin database , is the one for the user drawing style branch of the drawing style manager, make use you have a clean copy of the astoraddin.mdf database.
note that you should remove all *.ldf files, they are lock files associated with the main mdf files and not needed.
will try to find post over how to backup you data or move it another machine and post here later.
John Bennett
