Cut pipe to fit a round bend.
armenifer_projeto
armenifer_projeto
I want to make a cut in the vertical tube so that it can fit into the bend to be welded, but the cut is not coming out perfectly, there is a gap on one side and the other side fits inside the tube.
All round tube of 60, bend made with "curved beam".
mick-CNF
You will have to use transform elements, polar array on the feature.
If this information solves your problem please accept as a solution.
armenifer_projeto
Thanks for the reply.
The cut you made is much better than mine (yours is the bigger tube), the robot makes a few extra cuts but nothing that a little sanding can't fix.
I've never worked with the polar array, can you show me how you do it?
markhubrich
This also helps,
From experience, I would stay below 40. This makes any unwrap templates look nicer too.
...and fix the kiss export issues.
