Is it possible to cut beam by specifying two points or selecting the cut line?
Thank you,
Alex Borodulin
Thank you,
Alex Borodulin
For that you will need to use a Polygon contour from the features tab and draw the shape that you want to remove, just make sure you have your UCS set so the XY is on the beam web
Rob Merriman, Technical Specialist / Principal Structural Designer, OLG
That works!
Thank you, Rob.
Alex Borodulin
