Custom template (title block) addition
bimDRCDR
bimDRCDR
Hello guys,
I want to add custom template (title block) for fabrication drawing sheets. I couldn't load that custom template in prototype folder, but i am able to load in assembly drawing sheets. If anyone knows solution for this, please reply.
Sebastian_Eiche
Could you maybe create a video or do some pics for us?
Your explanation sounds a bit like a block problem...maybe the block is already existing...do you try 'purge' and then purge the blockname hypersteelpageheader?
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
bimDRCDR
I have to use same title block for both assembly and detail drawings. I could load my title block for assembly drawing but I couldn't load for my detail drawings. Can you have any solution for this.
Sebastian_Eiche
The titleblock had to be changed on the prototypes...maybe this helps:
https://www.youtube.com/watch?v=5OfMxmTOXFk
https://knowledge.autodesk.com/support/advance-steel/learn-explore/caas/CloudHelp/cloudhelp/2017/ENU...
Sebastian Eiche
bimDRCDR
I want to use this custom title block for detail drawings. It is available in assembly drawing prototypes.
But it is not available in detail drawing prototype templates and I also can't able to edit these title blocks.
If you have any solution for this, please share. I have been looking solution for this last couple of days.
Sebastian_Eiche
Ohhh I see a "Copy of..."
The prototype which is used in the process had to be filled in the field "Prototype" on the right side...
So you need to insert the filename by your own
Prototype: TITLE BLOCK.DWG
Sebastian Eiche
bimDRCDR
Hi @Sebastian_Eiche,
Thanks for the solution, it really works.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
