I have searched and read thru the forums and viewed many youtube videos with no success. I have been trying to add into Advance Steel 2019 a 3/8" A307 bolt for attaching stair treads to stringers. Any help would be greatly appreciated. I am currently detailing several large stair systems and this has been a major hangup. I just need a clear walkthrough or someway to import the 3/8" A307 bolt.
Thanks in advance.
have u triyed going to maneger (from tools tab)
then bolts
cee pic
if selected xox bolts but shorly be same with any bolt
on further investigation adding a bolt to bolt dont change what's available in stair macro
it seems to match the prefered sizes but no not quite
so im thinking u mite find sumet in the table editor with the big data base but i been looking throw and cant find any thing
You would think that autodesk would add these instead of the user having to create them. These are not custom bolts they are standard for connecting grating treads to stringers. The 1/2" bolt that is used wont quite fit in the tread since they are manufactured for a 3/8" bolt. One would think it would be easier for autodesk to create a 3/8"x1 1/4" bolt assembly than it would be for the user. All we need is one and the user can add on from there. Ive also noticed that if you have a dogleg at the top and create last tread it only adds the rear hole for the tread and not the front hole whats up with that.
iv manege to add a bolt
so first thing to realise was it is not a stair macro thing ,all things that let u put bolts in give u the same list of size options
u need to go to manager tools
bolts
then find the bolt type u use , make shore grade allso rite
then compare the ones that it lets u use to one it dont
the ones it dont let u use have most of the date field's blank
u need to fill in bank stuff so it more like the one u can use
then clos manager and adv st , reopen advs steel
i didn't fill in that much of table only put 2 bolts lengths in
and for sum reason the nut washer gos on wrong way round but the drawings got rite hole size
allso it would not let me give it rite size washer and nut
u can see in pic autodesk m12 to my m14
so to get bolt washer rite way round u need to put them in the rite way round
in set u need washer then nut , i had nut then washer before
allso u can add new washers an nuts
go to main tab on left there is bolt / nut / washer
uil need to add new bolt ,washer an nut
again ur just looking at the ones that work noticing the ones that don't have many blank fields
so fill them in to look like the ones that work
Hi Munrue,
I would also like this question answered. It seems like this 3/8" bolt for stair treads gets asked a lot, and the answers tend to be "watch this video" or "add it in management tools". I'm probably like you, tried to watch these videos and figure out the MT but couldn't. I recently did some stairs like this, couldn't figure it out, and used the 1/2" bolts then edited the callouts on the holes to be 7/16" dia! (Probably not the best work flow)
So I've tried watching videos, learning and going into MT, but I am stuck
My request to the experts is a step-by-step procedure with lots of screen shots on how to do this ONE simple(?) task. Add a 3/8" bolt to the A307 set. It seems like it should be easy, but I couldn't do it.
Regards
Ron Buckingham
i made a screen cast its uploading just now
its maybe not the best but i cant delete a bolt once i add it to connection list
so i cant remake screencast with out making new bolt and iv now got 3 unwonted bolts in list
for sum reason its called this last bolt i made 7 instead of 7mm
the m14 and m18 i made are labeled like others/properly
allso the bolt dont look that good the geometry values i put in are just a guess u can go back a change values later
allso the last tab bolts u may wont to try fill sum that in as it seems to have names
but i just made a bolt list and its showing m18 an m7 so maybe just leve that part
Hi munrue and alickomay,
I watched your screen cast and got some good tips. I also watched Advance Steel IQ #2 on youtube. I was finally able to add those 3/8" A307 bolts, but it was a long and complicated process.... I had no idea what was involved. I put all my steps in a pdf document which I am posting here. Hope it helps (it probably has some typos too)
Ron Buckingham
I’ve also reached the end of my patience with these simple fixes not being addressed yet. Let’s get some input from @Gernot.Jeromin
im looking for astorbase.mdb file to back up, but all i have showing is a astorbase.mdf file are these the same?
yer
thay changed database format last year
but meny documents will still say old format
Hmmm, that is funny..... when I saw your question, I figured it was just a typo on my part. I checked and the file I backed up was indeed astorbase.mdf, not astorbase.mdb. But I went back and looked at the youtube "Build your Advance Steel IQ #2 customizing bolts", the file is shown as mdb. That was where I had originally watched it (so "mdb" was in my head) but it looks like that file extension has changed to .mdf on later versions??
Ron
Hi Munrue,
There is a much easier way to achieve your desire.
You should now have the 3/8" bolt.
This work flow should not take more than 5 minutes!
Please see attached for the zip file and a Step by step Color PDF.
I hope this helped.
Best regards,
Graitec CANADA
Janet
My pleasure S. Lapoint!
I hope you like it.
I aime to please.
Janet
Graitec Canada
Thank you Janet, less than 5 minutes and i have 3/8 and 5/16 bolt assemblies. Once again Graitec to the rescue.
Also does anyone else have this problem when using grating treads. When a grating stair is drawn the last tread at the top only receives one hole in the stringer (the rear hole) the front hole has a bolt placed through the tread and stringer but there is no hole in stringer thus creating a clash.
