Advance Steel Forum
Welcome to Autodesk’s Advance Steel Forums. Share your knowledge, ask questions, and explore popular Advance Steel topics.
Create by template questions
2 REPLIES 2
katsanosengineer
154 Views, 2 Replies
When using the "create by template" and "create by template, multiple" options from the tool palette, I've realized that only the multiple option creates an editing box around the copied connection.
Things I would like to know:
1) why does this happen? is it supposed to?
2) if i can fix it and make it create an edition box, how could I?
Also, in certain instances,
i try to copy a connection and it won't accept the "multiple" choice, but it's fine if i use the singular one?
2 REPLIES 2
mick-CNF
in reply to: katsanosengineer
Select any part of the connection and right click the select joint properties and the box will appear.
Or click all visible which is OK but if you have other objects turned off they will all be visible again.
If this information solves your problem please accept as a solution.
katsanosengineer
in reply to: mick-CNF
THANK YOU SO MUCH!
