Countersink vs Countersunk holes
Julio_Soto
Advisor Advisor
Julio_Soto
What's the difference? For automatic labeling purposes, I am considering using the countersink hole definition for blind holes since AS does not have a way of distinguishing between a blind tapped hole vs a thru tapped hole.  However, I have no idea what a countersink hole, and I don't want to use it without knowing its purpose.
I found this thread but there was no answer. I'm hoping I can get an answer this time 😉
https://forums.autodesk.com/t5/advance-steel-forum/countersink-hole-definition/m-p/8727374
Sebastian_Eiche
as I know the countersunk hole is always through the whole material. So if you have a plate with 10mm the hole will have a depth of 10mm.
By using a countsink, the hole could be limited so this is what you called blind hole, it's just another naming in Advance Steel.
Both holes need different tabs for their creation
Sebastian Eiche
Application Engineer @Mensch und Maschine acadGraph
If this information was helpful, please use the Accept as Solution function, this make it easier for other users
Julio_Soto
I see what you mean. I feel like the blind hole and countersink could be the same object type. The only difference is the alpha parameter.  If you leave alpha 0, then a countersink looks and functions exactly like a blind hole.
It's funny, you just gave me an idea. What if I use the countersink for the pilot hole of a threaded hole and then make a threaded hole on top of it.  It actually looks like a halfway decent blind tap hole lol.  I wont do this myself I was just having fun haha. Maybe one day AS will be able to add blind threaded hole objects.
BTW, on the right is a countersink hole with alpha=0
Sebastian_Eiche
The problem is: two holes at the same place--> error in the NC files, one whole will be define with a * so this line will be not recognize from machines.
The most machines have problems to create a hole where another hole was already created.
It looks maybe nice but there're a few things which had to be seen too: DXF, NC file...what happened on drawings? Which one should be labeled?
Sebastian Eiche
Julio_Soto
Agreeed. I know there would be problems, that's why I said I wouldn't use it.
