Countersink hole definition
Masibanda-CE
Masibanda-CE
What is the purpose of the "Countersink" hole definition?
At first, I thought it was for Counterboring however it doesn't create a hole all the way through the part. Also, it doesn't drop the head into the counterbored material. What's the intention here ... does anyone use it?
acbsdesign
@Masibanda-CE
Sometimes I use them and give fabricators the nc files, usually trying to keep theoretically the head of the countersunk bolt 1/16" below the top surface,  angle of the head is usually 82 degrees. If the material is galv, the head will be flush with the top surface, so 1/16" is a common default for head to top surface distance.
It is used in plates supporting bridge stringers, in barges, walk pates (diamond plates) as well.
If this information was helpful, please use the Accept as Solution function, this makes it easier for other users.
Ilko Dimitrov, IDC-1, M. Eng.
Tekla and Advance Steel Detailer
ACBS Structural Steel Detailing
If it is made of steel, I can model it and detail it.
acbs-usa.com | Helpful Place
Masibanda-CE
@acbsdesign Ilko, I think you're referring to the "Countersunk" hole definition. Those do make sense and work as I would expect. It's the definition called "Countersink" that makes no sense to me.
Cheers,
Gary
acbsdesign
Ok, ok, I see what you are saying, I have no idea what is this for.
Julio_Soto
I'm glad I'm not alone on this.
acbsdesign
There are countersink drills on the market, but I have never seen countersink holes in a project. It may be some mechanical shops thing.
